Vray error: Sorry, can`t create output
  • Vray error: Sorry, can`t create output
    yo,
    anyone experienced this?
    happens when trying to save from VFb
    how do i get rid of it...dont wanna redo the scene from scratch
    thanks a lot for help
    best regards
    Martin
    http://www.pixelbox.cz
    When do you get this message? At the start of the rendering or at the end?
      the end...after i click on the save icon in VFB and specify the output path...strange, i can sometimes eliminate this by restarting max, but it does not work with this scene
      Martin
        this happened to me too, and was related to 3dsmax running out of memory after a particularly heavy render.
        the purpose of a ninja is to flip out and kill people.
        the purpose of an architect is to flip out and design for people.
        ________________________
        www.1050.pl / www.kinetik.pl
          indeed its a memory issue. Try render directly to .vrimg
          Dmitry Vinnik
          Silhouette Images Inc.
          ShowReel:
            yep
            but i have 8gigs of ram guys!!!
            will try to restart
            Martin
              it happens when two instances of max r open
              Martin
                Originally posted by PIXELBOX_SRO View Post
                yep
                will try to restart
                Stupid question but you didn't mention it... you are running x64 right?
                  yeah sorry guys, i should have done that in the first place
                  yep, running 64bits vistas as well..
                  closing the other max allows me to save the image , but still its a kinf of annoying...ive had still 3 gigs of RAM free
                  Martin
                    this stuff now happens on most of my scenes, even if i have only one max open...grrrrrrr...
                    my system resources show i have only 1.86Gb in usage...so its defo not a memory issue!
                    Vlado could you please help? i simply cannot finish a project with this bug happening
                    thanks a lot
                    best regards
                    Martin
                      what size/s are you rendering to?
                      Eric Boer
                      Dev
                        You say you are running 64bits Vista, but are you running 64bit Max?
                        Eric Boer
                        Dev
                          yep....all is 64bit, vista, max and vray
                          Martin
                            am running max9 64bit SP2
                            vray 1.50 SP2
                            vista ultimate 64bit
                            q6600@ 3.15GHz
                            8GB RAM
                            this happens even if the only program run is max and vray...
                            drives me up to the wall really...having to render to vrimg
                            nothing helps, restarting, reopening etc...thinking about reinstall but am really in a tight deadline here
                            on the other hand it forced me to start using vrimg)))
                            Martin
